When using table display mode in a dropdown list, I’ve noticed that if the width of the data in the column is less than the width of the header, the column is either just slightly too narrow to show the full header or just barely wide enough to show the header.
I have attached a screenshot that shows what I mean. The 1st and 5th columns are not wide enough to show the full header, the 2nd, 3rd and 4th are just barely wide enough, and the last shows the header no problem since the column data is wider than the header.
Adjusting the max table width has no effect.
I am using Ignitiuon 7.5.5
