Am I correct in assuming that both Bank and Machine are integers in the DB table?
SELECT
ROW_NUMBER() OVER(ORDER BY Bank ASC) - 1 AS 'value',
[label],
Bank,
Machine
FROM(
SELECT
Bank,
Machine,
MAX(c.[label]) AS 'label'
FROM
Cycle_Records_IS p
CROSS APPLY (SELECT 'Bank' + convert(nvarchar, p.Bank) + '-Machine' + convert(nvarchar, p.Machine) as 'label') AS c
GROUP BY
Bank,
Machine
)t1
Should give you what is expected for the first dropdown. There is probably better/cleaner SQL to achieve this; personally I'd only run
SELECT
Bank,
Machine
FROM
Cycle_Records_IS
GROUP BY
Bank, Machine
and place the result somewhere and use a script to loop through it and create the dataset for the dropdown.
Have a named query of
SELECT
Serial AS 'value',
Serial AS 'label'
FROM
Cycle_Records_IS
WHERE
Bank = :bank
AND Machine = :machine
ORDER BY Serial DESC
as the binding for the options dataset of the serial number dropdown. The parameters of the named query binding would be
lookup({path.to.first.dropdown.options}, {first.dropdown.select.value}, Null, 'value', 'Bank')
and
lookup({path.to.first.dropdown.options}, {first.dropdown.select.value}, Null, 'value', 'Machine')
for bank and machine respectively.
To make everything easier on yourself, create 4 custom properties on the root container of the window called machineByBank, selectedBankAndMachineIdx, availableSerials, and selectedSerial.
Have the first query as the binding for machineByBank, and bind the first dropdown's options dataset to this.
Bidirectionally bind the first dropdown's selectedValue property to selectedBankAndMachineIdx.
Bind the named query to availableSerials, and bind the second dropdown's options dataset to this.
Bidirectionally bind the second dropdown's selectedValue to selectedSerial
