Dropdown placeholder text
Hello!
When I delete values from a multiselect dropdown I want to show a message on the placeholder to clarify you need to have a value in order to aply filters
I delete the values with a button like:
    else:
        # Second click: Clear the selection
        dropdown.props.value = None
        self.parent.custom.selectAll = False
        self.props.image.icon.path = "material/done_all"
        # After resetting the value, update placeholder text
        dropdown.props.placeholder.text = "No hay ninguna sede seleccionada"
        dropdown.props.value = []
If I take out values manually the text appear,
If I do it with the button it doesn´t show any text:
I guess I need to trigger the internal logic of the dropdown placholder to do this.
Any ideas welcome.
Cheers.
I think the place holder only shows up when the props.value is null. The last line in the script sets it to [] not None (null).
Yeah, that´s it! thanks a lot @dkhayes117 !
    else:
        dropdown.props.value = system.util.jsonDecode("null")
You're in Jython. Shouldn't that be,
else:
Yes, with none it works also!
"none" won't work. "None" will.
