I have a template with a dropdown box and anytime the selection is changed I want it to write the value to a tag.
I used the Property Change script and it works fine, but I have a pop-up with six of these templates on it and anytime I open that pop-up with this script running it hangs for a couple of seconds - it didn’t hang before I added this dropdown. I purposefully put a bug in the script to see how many times it was actually running and I got 66 errors.
When I close the pop-up it also appears to run several times and hangs for a second.
I would except to see at least six since the initial value is pulled from a tag and that would constitute as a property change, but it looks like it is trying to run 11 times or more. Any insight as to what is happening would be great!
