I’m working with a dropdown menu and it is getting it’s data from a SQL query. When i start the program, it automatically selects one of the values. How do I make it so that ‘no selection’ is an option? And this option have a respective value? Any thoughts other than just creating a new entry in my Database that will pull it? Thanks so much!
Hi Alex!
Just ran into the same thing recently-- shooting my own foot there!
In the designer, set the selected index to -1, then save the project.
So now I feel silly, because I can’t even find that option under my property editor
Does my selection mode need to be on a certain setting? It’s on lenient, and the no selection value is -1. Still only displaying the 3 results returned from the query and not a 4th, ‘
Sorry, Alex, I misspoke-- or mis-typed…
Selected Value is the one you want. It’s right underneath Data
Ok, I see that and I see what it is doing on startup, but is there a way to make it a permanent option? After I select an option, the a * , I would be able to essentially return all rows of a table.
Maybe there is an easier way to do this? ![]()
I’m not sure if this will work in your project, but in my dropdown scripting I added the line:
event.source.selectedValue = -1
and it seemed to work for me. Sets the index back to -1 after it goes through the rest of the script.
Ah! I see what you mean, Alex.
I use something like this for the Data property:
SELECT 'All'
UNION ALL
SELECT DISTINCT column_name
FROM table
This will put the option ‘All’ at the top. You can then modify your where clause to fit what you want to do.
Hope this helps!
This is the SQL Query for the table I have on my page
SELECT * FROM workorders
WHERE clientname = '{Root Container.Dropdown.selectedStringValue}'
AND problem LIKE '%{Root Container.Text Field.text}%'
My WHERE statement is looking at the dropdown menu for the value in client name. Since I do not have any clients with the name ‘ALL’ it won’t return all of the values. I’m sure there is a better way to do this. Honestly, it’s not a huge problem if i don’t get it working, it would just allow me to search across all entries based on the search parameter instead of limiting it to just the one client.
You can use a custom property to hold the WHERE clause.
if({Root Container.Dropdown.selectedStringValue}="All",
CONCAT("WHERE column_name = ", {Root Container.Dropdown.selectedStringValue})
Then your query would be something like:
SELECT *
FROM table
{Root Container.whereClause}
Another solution would be to form your query like this.
WHERE (clientname = '{Root Container.Dropdown.selectedStringValue}' OR '{Root Container.Dropdown.selectedStringValue}' = 'All')
