[Duplicate]Deleting duplicate properties or parameters
If I create a view parameter or custom property with the same name as an existing parameter/property, it is (correctly) flagged as a duplicate by the designer. Then when I select one of the duplicates and delete it, it deletes both instances, not just the duplicate. Is this a bug?
