I have a tag change script that watches a string tag and on value change I have it open an instance of a window. The windows location is set dynamically and I pass the desired parameters in and they pop up where I need them.
However, If there is a window open in position 1 and the same tag changes while its current instance is up, it creates another instance in the same position and changes the text on both.
Is there a way to open only one instance and have the text change without having another instance open directly on top of it for the same location?
