Duplicate Page in Reporting
Hello,
I am having a strange problem in the reporting module; my project browser shows only one page under my report but I am seeing a duplicate page 2 in the preview/actual report.
Anyone know why this is?
Steve
Was this ever figured out? I have the same issue. Not sure how to get rid of the duplicate page.
There are a few edge case things to check for, such as make sure there are no components floating off on the side, or any component boundaries that are stretched further than expected.
White space in Reporting is extremely literal and extremely sensitive, so one thing to try assuming you are dealing with a Table repeating - is slightly decrease the height of the table or components in the table until the repeat doesn't happen. There is also a chance that turning off the setting "Reprint When Wrapped" on the component may help as well.
I would duplicate the report and test one thing at a time to see if it improves the behavior.
Yep that was the issue, I had a table that wasn’t extended down far enough by a pixel or so. Thank you for your help!
