Duplicate rows SQL data from transaction groups
I have one transaction group (store proc) running and every time I hit a trigger to fire the transaction group, I see the #executions increment by 1 in the Ignition designer, but I see two new rows of SQL data (almost identical timestamps).
Any idea what is causing this?
There were to instances of the transaction groups running. I’m not exactly sure how I got two transaction groups running… but I did. I noticed them in the main web-based control panel. Removing one of the duplicated transaction group, fixed the issue.
Thanks a ton to Inductive’s support team.
I'm having the same issue. How did you check the main web0based control panel? I'm hoping my issue is as simple as that
This topic is almost 10 years old. Please make a topic of your own and include some more detailed info for it. Without knowing what your transaction group setups are there is not much we here can do for you.
