Dynamic Alarm configuration
Hello Team,
We are looking for configuring dynamically alarms multiple tags by Ignition UI, we are using function 'Result=system.tag.configure(baseTagPath, tags, collisionPolicy)'
initially when we set up 'collision Policy' ='O'. It was resetting all existing configuration tag configuration. It is expected behavior.
But if we setup 'collision Policy' ='m', In case we are getting error:'Error_Exception' & please refer gateway error. (We cross checked tag path is correct)
Please help us resolve issue?
Regards,
Dhiraj Pawar
Null pointer exceptions are always a bug. You should report this bug to IA support. Only someone with access to that spot's source code will be able to figure it out. (This forum is not support.)
