Dynamic Bar Graph Segment Colors and using SQL query to populate the graph
I am populating the bar graph using the sql query in the report viewer. I am successfully able to populate the bar graph however I would like the bars colour based on condition such as (Please see Bar Chart 1).
Now looking through the forum I found some pointers but the examples were associated to when the bar chart is used in the vision screen. Unlike the bar chart properties in vision screen where one can easily use getBarColor Extention to dynically colour the bars based on the condition, I couldn’t find something similar in the report viewer window.
Here is how I want the bar screen to look (Please Note: This bar screen was populated in the vision window and I used getBarColor extention and code used is below this graph)
BAR CHART 1 - Inserted in Vision Window
’from java.avt import Color
if value >= 4.3:
return Color.RED
if value > 4 and value < 4.3:
return Color.GREEN
else:
return defaulColor’
Now, in the report viewer when I am populating bar graph using sql query, it is noticed that they are all one colou**r. **
BAR CHART 2 - Created in Report Viewer
I am guessing in order to add dynamic colour to the bars I need to use the ‘configurechart’ definition in the report viewer found under the configuration. Please see below the screen shots
I believe the code will go here but I don’t know how to properly do this.
In a nut shell, could you please provide assistance as to how I can fill the bar’s in the bar chart dynamically based on condition in the report viewer window.
Bumping the thread! Any help would be highly appreciated.
I don’t know how to do this, but I might can give some feedback. Make sure your code is indented so it is inside the
def configureChart(chart)
Then you probably want to do something like
if data['VAL'] >= 4.3:
        chart.setColor.GREEN
else:
        chart.setColor.RED
I don’t know the correct syntax for the chart.setColor, or even if that is correct, but it might help you a little bit. check the JFreeChart API
Thank you for the direction. I will try to build up on your code and hopefully I get it to work. Thanks!
I contacted Ignition Technical support and they were able to provide me with the solution. I am posting it here incase anyone else needs to use it in future. Thank you again.
In the report properties, scroll down to enable script and add this script in there. Please pay attention to tables otherwise it may not work.
    from java.awt import Color
    from org.jfree.chart.renderer.category import BarRenderer
    class CustomRenderer(BarRenderer):
    def getItemPaint(self, row, column):
	v = chart.getCategoryPlot().getDataset().getValue(row, column)
	if v >= 4.3:
		return Color.red
	if v > 4 and v < 4.3:
		return Color.green
	else:
		return Color.blue
     chart.getCategoryPlot().setRenderer(CustomRenderer())
def getBarColor(self, series, category, value, defaultColor):
dataset = self.parent.parent.parent.dataset
color1 = Color(73,186,183) #green
color2 = Color(255,0,0) #Red
rowcount = dataset.getRowCount()
for i in range(rowcount):
	status = dataset.getValueAt(i, "status")
	if status == 'Completed' :
		return color1
	if status != 'Progress' :
		return color2
I'm using this script and in for loop if I print i which is giving me zero alone
I have a custom property in which it contains 3 columns and 30 rows.
Why its always showing zero in the for loop and it is not working because of this, Please support on this.
It seems that you are not understanding how this extension function works. There is no need to iterate, the function does that automatically with category being the row and series being the column. (Note that series is zero indexed and ignores the label column). That said, there is no need to do a self.data.getValueAt(category, series + 1) call because that is already done with the value variable. You can just use the value variable.
Also, this seems off to me:
My expectation would be: `dataset = self.data"
Putting it all together, I imagine that your script should look more like this:
#def getBarColor(self, series, category, value, defaultColor):
	dataset = self.data
	status =  dataset.getValueAt(category, "status")
	if status == 'Completed':
		return color1
	elif status != 'Progress':
		return color2
	else:
		return defaultColor
Also note that the extension function won't directly bark at you if there is an error in your code. You will have to open up the console to see if there is a problem (ctrl+shift+c).
