Create a power table with test data and paste the following into the configureEditor extension function.
Make the String Column editable.
[code] from javax.swing import AbstractCellEditor,JComboBox
from javax.swing.table import TableCellEditor
class myTableCellEditor(TableCellEditor,AbstractCellEditor):
def __init__(self, tableComponent):
self.table= tableComponent
self.cbValues = None
def getTableCellEditorComponent(self, table, value, isSelected, rowIndex, vColIndex):
# Contents of dropdown will be dependant on this value.
intColumnValue = self.table.data.getValueAt(rowIndex,"Int Column")
# You can change this to query a database table or hardcode values
newList = [intColumnValue + i for i in range(0,10)]
# Build the Combo box with the values from above
self.cbValues = JComboBox(newList)
return self.cbValues
def getCellEditorValue(self):
return self.cbValues.getSelectedItem()
if colName == "String Column":
m = myTableCellEditor(self)
return {"editor":m}[/code]
