Hello ,
I'd like to know how to modify the X and Y position dynamically in relation to an int tag in a group containing text and shapes.
thank you.
Hi, and welcome to the forum! ![]()
Is this for vision or perspective? The question hints at vision, but it's good to be on the same page.
Hello ,
thank you for the welcome
yes it's for Vision
This doc might be helpful for you:
Thank you,
but where do I write this code to animate the group?
If you want the code to update whenever a tag value is updated then I'd recommend you create a custom prop on your component (group, container, etc) then bind your tag or a timer to the property.
Then on the component use code like this on the propertyChange event handler script on the component:
# Easier for repeatability you can also have multiple properties move this component
def moveComponent(xPosition, yPosition):
DURATION = 500 # Duration is in ms, if left blank then the transform will happen straight away.
system.gui.transform(event.source, newX=xPosition, newY=yPosition, duration=DURATION)
if event.propertyName == "customPropName1":
# Get your x and y values here and assign them to a variable (can be done by reading a tag, etc).
x = 100
y = 100
moveComponent(x, y)
elif event.propertyName == "customPropName2":
x = 110
y = 110
moveComponent(x, y)
Hopefully this helps!
Thank you,
it worked
