Dynamic path to params
Hello,
O try to figured out how to make this work.
value =  self.getSibling("EmbeddedView").props.params.Score_Parameter
self.getSibling("EmbeddedView").props.params.S_2639 = 6
however, the last bit “S_2629” I would like to get dynamically from variable as it need to be dynamic.
I tried simple:
self.getSibling("EmbeddedView").props.params. + value  = 6
But obviously no luck.
Thanks for your help.
Best regards
Pawel
use [ ]
self.getSibling("EmbeddedView").props.params[value] = 6
Thanks victordcq
It’s working perfect.
Is there a similar way to do this in expressions.
{view.params.S_2369}
to be
{view.params.{this.meta.name}}
For expressions, you can use the property function.
Thank you guys for your help.
