Dynamic Perspective Popup Title
I’m having some issues utilizing the Popup action to change the title of a popup dynamically.
I have strings stored within the PLC (think PlantPAX) that I want to be able to use in the title of a popup. This way I would be able to just have a single popup for a device and not have to change each instance of calling it.
I would make a title within the view that I’m using in the popup but it looks bad when I leave dragging on.
Hi @b.peck, you could use the scripting action instead and use the system.perspective.openPopup() function. You should be able to pass in any title you like there.
Here is the documentation regarding the scripting function.
Thank you. I appreciate the help.
