Can you add the Dynamic Properties keyboard shortcut back in?
It would also be nice if in Designer when you double clicked on an item the Action Configuration window would open for that item.
Hmmm… yeah we lost the shortcut to the customizer when we introduced multiple customizers…I suppose we could add in a short cut that went to the first customizer, or we could add shortcuts for the dynamic properties customizer and a separate one for the styles customizer…we’ll think about that one.
Double-clicking action is something we’ve thought about. I think it needs to be ‘smarter’ than that. For example, if you double click on a button, you should probably get the action config, but if you dbl click on an easy chart, you should get its customizer. We’ll put that on the list too.
Thanks for the suggestions,
