Dynamic Tag Path
I’m trying to create a custom tag path based on custom parameters.
The following works…
tag("[MQTT Engine]/Edge Nodes/Cabinets/BB-003/Info/Alarm")
The following doesn’t
tag("[MQTT Engine]/Edge Nodes/Cabinets/{view.params.id}/Info/Alarm")
view.params.id = BB-003
I assume I’m missing some kind of formatting but cant figure out what it is. This is for a expression on a label.
Thankyou
You have to concatenate your tag path with the variable. Right now the whole tag path is a literal string.
tag(“firstPartOfPath/” + view.params.id + “/endOfPath”
Yes. If this is for a binding, consider using an indirect binding instead of the tag expression for better performance.
Indirect Tag did the trick…
[MQTT Engine]Edge Nodes/Cabinets/{Serial}/Info/Device Info/Last Data Message Size
Then you define {Serial} in the property box underneath.
