I am just learning to use the SFC module, and was wondering if there is a way in the transition script to make the values dynamic for both tags and for custom chart parameters.
For example, I want each instance to be passed a High Temp limit. Then during one of the transitions check to see the value for the PV for the furnace I am running a sequence for (this is a dynamic tag reference) is below the passed temp limit.
Thanks for the help.
Scott
