Dynamic UDT path in script
Hello all,
I have UDT called order and it includes an orderNo and state value.
The orderNo value is coming from a named query and the return mode is set to JSON, I have a transform script to return the state value of each orderNo but it does not work. It returns null instead of the value:
	list = []
	for i in range(value):
		dict = {
            "id" : i+1,
			"state": system.tag.read("[default]Order/Order"+"id"+"/State"")
		list.append(dict)
	return list
You have quotes around what I presume is intended to be code. Try:
	list = []
		dict = {
			"state": system.tag.read("[default]Order/Order"+self.custom.orderNo[i].order_number+"/State")
		list.append(dict)
	return list
That does not work it says cannot concatenate int and str.
I changed my code to:
still does not work
	list = []
		dict = {
            "id" : i+1,
		list.append(dict)
	return list
self.custom.orderNo[i].order_number is an integer so you must convert it to a string.
	list = []
		dict = {
			"state": system.tag.read("[default]Order/Order" + str(self.custom.orderNo[i].order_number) + "/State")
		list.append(dict)
	return list
That worked! Totally forgot about that!!! Thank you so much!!!
