Dynamically adjust parameters of trapezoid
Is there a straightforward to dynamically adjust a trapezoid in Perspective? Normally you only have the two dimensions (width, height) and would like a little more independent control.
You could dynamically modify an SVG.
What type of parameters are you looking to control?
Just looking to control height on ends
Sure.
Obviously you can get much more complex than this, but it should serve as a good enough example to get you started.
trapezoid
Copy the JSON below and paste it into a view to see the how I did it.
  "custom": {},
  "params": {},
  "props": {
    "defaultSize": {
      "height": 762,
      "width": 1055
  "root": {
    "children": [
        "meta": {
          "name": "blank"
        "position": {
          "height": 150,
          "width": 600,
          "x": 50,
          "y": 78
        "propConfig": {
          "props.elements[0].d": {
            "binding": {
              "config": {
                "expression": "max({../Slider.props.value},5)/100 * 40"
              "transforms": [
                  "expression": "concat(\"M10 40 L190 40 L180 \", {value}, \" L20 \", {value}, \"Z\")",
                  "type": "expression"
              "type": "expr"
        "props": {
          "elements": [
              "fill": {
                "paint": "#00000000"
              "stroke": {
                "paint": "#000000"
              "type": "path"
          "preserveAspectRatio": "xMinYMin",
          "viewBox": "0 0 200 50"
        "type": "ia.shapes.svg"
        "meta": {
          "name": "Slider"
        "position": {
          "height": 39,
          "width": 365,
          "x": 79,
          "y": 241
        "props": {
          "labels": {
            "interval": 10,
            "show": true
        "type": "ia.input.slider"
        "meta": {
          "name": "Label"
        "position": {
          "height": 32,
          "width": 50,
          "x": 507,
          "y": 244.5
        "propConfig": {
          "props.text": {
            "binding": {
              "config": {
                "path": "../Slider.props.value"
              "type": "property"
        "type": "ia.display.label"
    "meta": {
      "name": "root"
    "type": "ia.container.coord"
This has helped. Taken me a bit to figure it out but think I am getting there. Thanks,
Can I ask one more question. How are you creating your image/drawing Seems to be stored inside ignition. I have used Inkscape but am not able to change it to a drawing.
When you drag and drop an SVG file on to your view in the designer, you are presented with a dialog which gives you the option to either Save and link or Embed image.
If you choose embed the SVG will be inserted into the view as a drawing object.
Here is a small example of how I do this for small less complex (my definition of complex is probably different than most when it comes to SVG) images.
Thanks again. Will try it out.
