Dynamically adjust xy chart length
hi ,
In one of my charts , when values are high its not visible unless in hovering . So how to dynamically adjust the chart length based on the values
What kind of chart is this? Which module is this? ...Vision, Perspective, Reporting?
Hi ,
module is perspective and chart is XY chart.
I have attached one of the chart binding for your reference
    "type": "ia.chart.xy",
    "version": 0,
    "props": {
      "enableTransitions": true,
      "background": {
        "render": "gradient"
      "xAxes": [
          "name": "iMins",
          "label": {
            "enabled": true,
            "text": "MTTR in Mins",
            "color": ""
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": false,
          "render": "value",
          "category": {
            "break": {
              "enabled": false,
              "startCategory": "",
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": false,
              "timeUnit": "hour",
              "count": 1,
              "skipEmptyPeriods": false
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
            "inputFormat": "yyyy-MM-dd kk:mm:ss",
            "format": "M/d/yyyy HH:mm:ss"
          "value": {
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "logarithmic": false,
            "break": {
              "enabled": false,
              "startValue": 0,
              "endValue": 100,
              "size": 0.05
            "format": "#,###.##"
          "appearance": {
            "opposite": false,
            "inside": false,
            "labels": {
              "color": "",
              "opacity": 1,
              "rotation": 0,
              "verticalCenter": "middle",
              "horizontalCenter": "middle"
            "grid": {
              "color": "",
              "opacity": 0,
              "dashArray": "",
              "minDistance": null,
              "position": 0.5
            "font": {
              "size": "",
              "weight": 500
      "yAxes": [
          "name": "iReason",
          "label": {
            "enabled": true,
            "text": "",
            "color": ""
          "visible": true,
          "tooltip": {
            "enabled": true,
            "text": "",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "inversed": false,
          "render": "category",
          "category": {
            "break": {
              "enabled": false,
              "endCategory": "",
              "size": 0.05
          "date": {
            "baseInterval": {
              "enabled": false,
              "timeUnit": "hour",
              "count": 1,
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startDate": "",
              "endDate": "",
              "size": 0.05
          "value": {
            "range": {
              "max": "",
              "min": "",
              "useStrict": false
            "break": {
              "enabled": false,
              "startValue": 0,
              "endValue": 100,
              "size": 0.05
          "appearance": {
            "opposite": false,
            "inside": false,
            "labels": {
              "color": "",
              "opacity": 1,
              "rotation": 0,
            "grid": {
              "color": "#2B2B2B",
              "opacity": 0,
              "dashArray": "",
              "position": 0.5
            "font": {
              "size": "",
              "weight": 500
      "series": [
          "name": "Reason",
          "label": {
            "text": "Downtime reason"
          "visible": true,
          "hiddenInLegend": true,
          "defaultState": {
            "visible": true
          "data": {
            "source": "example",
            "x": "iMins",
            "y": "iReason"
          "xAxis": "iMins",
          "yAxis": "iReason",
          "zIndex": 0,
          "tooltip": {
            "enabled": true,
            "text": "[bold]{valueX}[/] mins",
            "cornerRadius": 3,
            "pointerLength": 4,
            "background": {
              "color": "",
              "opacity": 1
          "render": "column",
          "candlestick": {
            "open": {
              "x": "",
              "y": ""
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
              "deriveFieldsFromData": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "column": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "fill": {
                "color": "#000080",
                "opacity": 1
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "stacked": false,
              "width": 10,
              "height": 15,
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "heatRules": {
                "enabled": false,
                "max": "",
                "min": "",
                "dataField": ""
          "line": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": false,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "text": "{name}: [bold]{valueY}[/]",
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "stepLine": {
            "open": {
              "x": "",
              "y": ""
            "appearance": {
              "connect": true,
              "tensionX": 1,
              "tensionY": 1,
              "minDistance": 0.5,
              "stroke": {
                "width": 3,
                "opacity": 1,
                "color": "",
                "dashArray": ""
              "fill": {
                "opacity": 0,
                "color": ""
              "bullets": [
                  "enabled": true,
                  "render": "circle",
                  "width": 10,
                  "height": 10,
                  "label": {
                    "text": "{value}",
                    "position": {
                      "dx": 0,
                      "dy": 0
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "rotation": 0,
                  "tooltip": {
                    "enabled": true,
                    "cornerRadius": 3,
                    "pointerLength": 4,
                    "background": {
                      "color": "",
                      "opacity": 1
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                    "rotation": ""
                  "heatRules": {
                    "enabled": false,
                    "max": 100,
                    "min": 2,
                    "dataField": ""
          "candlestick": {
            "appearance": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "fill": {
                "color": "",
                "opacity": 1
              "heatRules": {
                "dataField": "",
                "enabled": false,
                "max": "",
                "min": ""
              "stacked": false,
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
            "high": {
              "x": "",
              "y": ""
            "low": {
              "x": "",
              "y": ""
            "open": {
              "x": "",
              "y": ""
          "column": {
            "appearance": {
                "fill": {
                  "color": "",
                  "opacity": ""
                "stroke": {
                  "color": "",
                  "opacity": "",
                  "width": ""
              "fill": {
                "color": "",
                "opacity": 1
              "heatRules": {
                "dataField": "",
                "enabled": false,
                "max": "",
                "min": ""
              "height": null,
              "stacked": false,
              "stroke": {
                "color": "",
                "opacity": 1,
                "width": 1
              "width": null
            "open": {
              "x": "",
              "y": ""
          "data": {
            "x": "iMins",
            "y": "iReason"
          "defaultState": {
            "visible": true
          "hiddenInLegend": false,
          "label": {
            "text": ""
          "line": {
            "appearance": {
              "bullets": [
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "rotation": "",
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                  "enabled": true,
                  "fill": {
                    "color": "#000000",
                    "opacity": 1
                  "heatRules": {
                    "dataField": "",
                    "enabled": false,
                    "max": 100,
                    "min": 2
                  "height": 10,
                  "label": {
                    "position": {
                      "dx": 15,
                      "dy": 25
                    "text": "{valueX}"
                  "render": "label",
                  "rotation": 0,
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "tooltip": {
                    "background": {
                      "color": "",
                      "opacity": 1
                    "cornerRadius": 3,
                    "enabled": true,
                    "pointerLength": 4,
                  "width": 10
              "connect": true,
              "fill": {
                "color": "",
                "opacity": 0
              "minDistance": 0.5,
              "stroke": {
                "color": "",
                "dashArray": "",
                "opacity": 0,
                "width": 3
              "tensionX": 1,
              "tensionY": 1
            "open": {
              "x": "",
              "y": ""
          "name": "",
          "render": "line",
          "stepLine": {
            "appearance": {
              "bullets": [
                    "fill": {
                      "color": "",
                      "opacity": ""
                    "rotation": "",
                    "stroke": {
                      "color": "",
                      "opacity": "",
                      "width": ""
                  "enabled": true,
                  "fill": {
                    "color": "",
                    "opacity": 1
                  "heatRules": {
                    "dataField": "",
                    "enabled": false,
                    "max": 100,
                    "min": 2
                  "height": 10,
                  "label": {
                    "position": {
                      "dx": 0,
                      "dy": 0
                    "text": "{value}"
                  "render": "circle",
                  "rotation": 0,
                  "stroke": {
                    "color": "",
                    "opacity": 1,
                    "width": 1
                  "tooltip": {
                    "background": {
                      "color": "",
                      "opacity": 1
                    "cornerRadius": 3,
                    "enabled": true,
                    "pointerLength": 4,
                  "width": 10
              "connect": true,
              "fill": {
                "color": "",
                "opacity": 0
              "minDistance": 0.5,
              "stroke": {
                "color": "",
                "dashArray": "",
                "opacity": 1,
                "width": 3
              "tensionX": 1,
              "tensionY": 1
            "open": {
              "x": "",
              "y": ""
          "tooltip": {
            "background": {
              "color": "",
              "opacity": 1
            "cornerRadius": 3,
            "enabled": false,
            "pointerLength": 4,
          "visible": true,
          "xAxis": "iMins",
          "yAxis": "iReason",
          "zIndex": 0
      "style": {
        "borderStyle": "outset",
        "marginLeft": 5,
        "marginRight": 5
      "dataSources": {
        "example": []
    "meta": {
      "name": "ch_mttr"
    "position": {
      "grow": 1,
      "basis": "45%"
    "custom": {}
Thanks. I've added the Perspective tag to this topic.
