Dynamically Binding to Multiple Tags
Hello,
I'm working on a vision template where I'm needing to bind to an unkown number of tags.
Essentially, on the template I'll have an ID custom prop which I can use to query a database.
The query will produce a number of tag paths to some boolean tags for which I need to check the value of each and check if any of the values are true. That true or false will be stored in a custom prop to hide or show a component.
I can't think of a way to do this with bindings but I thought I would ask.
My other thought was to use a timer component with a script that polls regularly, though I know that's generally seen as a bad practice.
Any ideas?
Maybe try this module from @pturmel
