Is it possible to dynamically modify the email subject and body so that I can include tag values to it.
For example I have two tags named "tank_count" and "cycle_count" with integer values which I want to include in the email subject like this:
PULSATION RESULTS: Early Failure <tank_count><cycle_count>
event value is not possible for my case.
can anyone help me with this?
It shouldn't be a problem to cast the values to a string and concatenate them in your header and body strings. Where are you scripting this from?
inside the notification block, where we can modify email subject and body.
I guess I'm not sure what we're talking about. This isn't a system.net.sendEmail SMPT script? We're trying to automatically inject live tag values into an email component of some kind?
I created a alarm notification pipeline in which i would like the email notification to be displayed as follows:
Sub:
"PULSATION ALARMS FOR"+{[IGNITION_TAGS]PULSATION/Rig_10/Model_Number}+"TANKS"
Body:
"Rig "+[IGNITION_TAGS]PULSATION/Rig_10/Station_Name_ +"Faulted at "+[IGNITION_TAGS]PULSATION/Rig_10/Total_Pulses+ "cycles".
Is this possible through notification block or should i create a custom message for each alarm.
Use the </> button to format code in your posts. This will preserve indentation and apply syntax highlighting.
Use > when quoting someone else.
You can fix your post using the 🖉 link below it.
Isn't this method used for html formatting ?
if I want to display a tag value along with the message should I use ">"
what did u mean by the last sentence?
This forum uses Markdown to format posts. This is converted to HTML when the post is rendered.
if I want to display a tag value along with the message should I use ">"?
No. Only use the> quotation Markdown when you are quoting someone else's words (as I have quoted you above).
Sorry, you should have seen the pencil icon there. There's one under your post so you can edit it.
