I have been using the standard chart for displaying a calulated series of points. This has been working great so far. The data is a delimmited string of numbers that I have to calculate and store to a dataset and represents material thickness
I added a check box to the screen to allow the user to change the thickness from inches to a percentage of the target. When in “percent mode” I want to change to an area renderer but cannot figure out how to change this in script. Is this possible with the standard chart?
I considered using the easy chart since it has a pens table with a column for renderer_style but my data is in a calculated dataset and not in a table. Is there a way to bind to a dataset?
You can see what the original string looks like in this post.
http://www.inductiveautomation.com/forum/viewtopic.php?f=15&t=3717
