Hi all. I'm currently attempting to take the results of a named query and pass them into a geoJSON file so that my route will be dynamically displayed on my perspective map component. Preferably I'd like to make it auto-update as new data is coming in as well.
Is there a way to do this via scripting or something similarly internal as I'm trying to avoid constantly uploading new files to display this data.
Step 2: once you've bound the file and all the drop downs are in the correct spots remove the binding to the webdev file
Step 3: drill down till you find the ''Coordinates tab" and perform a named query binding on it to return your geolocation data of interest and be sure the return type is set to data-set
Step 4: Make a scripting transform on the coordinate binding and read the following posts
As of right now this seems to work. If there is any change or if I find a better way I'll update this post
