I have the python script that is reading files out of a folder, i wanted to dynamically populate a tree view with the data.
What I have done to this point was add a script to the app module that works fine. Then i added an expression to the data/item of the tree view. when it opens i get an error:
Cannot coerce value 'C:\path\file.csv' into type: interface
I am new to ignition and I’m not sure how to link the two. I was wondering if anyone could point me in the right direction, thx.
should probably post your scripts and a better example of what you are trying to accomplish. are you trying to read data out of a csv file and use that data to build a dataset for a treeview component?
Thanks for the reply, im reading a folder on my C drive, taking the filenames out of the folder and I wanted them to display in the treeview.
Here is my app script:
def treeList(path = r'C:\folder\\'):
import os, csv, glob
#read all the files in a folder
files = []
for fileName in glob.glob(os.path.join(path,"*")):
files.append(fileName)
return files
here is what I have listed in the data > Items script:
runScript("app.Tree_View.treeList()")
Here is the error I’m getting, it is listing the files but tells me:
Cannot coerce value '['C:\\folder\\file1.csv', 'C:\\folder\\file2.csv']' into type: interface
Im guessing its the way im trying to link the data to the tree, does anyone have any experience trying to do this? Thanks
yes you need to take a look at the dataset in the treeview component and make whatever data you are pulling from those files formatted to match that dataset.
Thanks Diat150,
I tried formatting my returned values a little, but I am a little unsure how they are supposed to match. I read how I need to have the path along with the name, I believe that those are the only required items. I then changed my python to return (path, name) but it still does not work.
Do i need to keep the names with the value in my script, ie… path => ‘c:/folder’, name => ‘filename.txt’? I’ll try that next and see if it works but I feel like Im spinning my wheels a little, thanks.
I have modified my scripts, I now have a button that calls a script module to populate the tree view for now.
My module script:
[code]def treeList(fpath = r’C:\Folder\’):
import os, csv, glob, system
rows = []
for fileName in glob.glob(os.path.join(fpath,"*")):
tail, head = os.path.split(fileName)
rows.append([tail, head])
return rows[/code]
button script:
[code]import app
rows = app.treeView.treeList()
#create event handler
headers = [“path”, “text”]
fileList = system.dataset.toDataSet(headers, rows)
Use our new dataset to fill in a tree view
#treeV = window.rootContainer.getComponent(name)
treeV = event.source.parent.getComponent(“csvList”)
treeV.data = fileList[/code]
Error:
[code]Traceback (most recent call last):
File “event:actionPerformed”, line 11, in
java.lang.UnsupportedOperationException
java.lang.UnsupportedOperationException: java.lang.UnsupportedOperationException
caused by UnsupportedOperationException
Ignition v7.6.1 (b2278)
Java: Oracle Corporation 1.7.0_25
[/code]
I am now getting a different error that I am not sure what to do with. Hopefully someone can chirp in with some direction, thanks.
I got it working, but I got a list populating. Ill have to work on the tree view later.
