E-Iologik to Ignition
Having trouble with the right combination for an Iologik E1240 to hook it to Ignition.
I have tried several combinations, but cant pass the values properly into the Ignition Server.
Does anybody have the proper setup in either the OPC Server or the sql tag to make it work?
I know that they are 32bit floats Least Significant Register first.
You’ve probably figured it out by now… but for others with the same query: https://youtu.be/RDcFgat6_sc
