I have agents that sync the remote tag providers UDT's with the standard tag provider. When I run this task I get a timeout error almost everytime. Even with the error, it works sometimes, but I would like to narrow down the why and the fix to this reoccuring error.
Here is the error.
Thank you for your help!
com.inductiveautomation.metro.api.ex.TimeoutExpiredException:
TimeoutExpiredException[queueId=_default_, targetIntent=_services.invoke_|2,
msgData=com.inductiveautomation.eam.gateway.services.SendTagsService#importJson([class java.lang.String, class [B])]
at com.inductiveautomation.metro.impl.queues.StandardQueue.processTimeouts(StandardQueue.java:231)
at com.inductiveautomation.metro.impl.queues.StandardQueue.lambda$maybeScheduleTimeoutChecker$1(StandardQueue.java:213)
