EAM Backup Tasks
I am collecting backups for several Ignition Gateway servers via EAM. I am able to see the list of backups, but I do not see any way to purge old backups? Is there something somewhere what I am missing? It would be nice to only keep the last xx Days and purge everything else.
Yeah, the EAM doesn’t currently have that functionality. It’s a great candidate for http://ideas.inductiveautomation.com though. On the EAM controller, you can manually set the archive path to a specified folder. This makes it easier to build an automated script that can remove gateway backup files older than XX days.
I built a user screen to display, prune and fetch EAM backups from the EAM gateway. There are four button scripts, and two client gateway event scripts and two client gateway scripts. If your interested send me a note and I can send you the project. I was going to post the code here but it just got to long.
To get a idea of who it works the screen looks like this;
My approach was to write a global script that deletes all the backups except for the number of backups that I choose to keep.
I execute this script as a tag event script on an expression tag that runs nightly an hour before the scheduled agent task for backup runs. You could also run it on schedule from a Gateway Event script.
def deleteOldBackupFiles():
#	Purpose:	To delete old backup files to prevent disk full condition on the server hard drive
#	Change Management
#	Date		Who				What
#	22-Jan-2019	Lynn Martineau	original version
	# import libraries
	import glob			# used to get directory and file names
	import os			# used to delete files and remove directories
	# initialize variables
	backupFilePath = system.tag.read( 'Config/BackupFilePath' ).value
	backupRetentionCount = system.tag.read( 'Config/BackupRetentionCount' ).value
	backupFileMask = system.tag.read( 'Config/BackupFileMask' ).value	# this prevents deleting non-backup files/folders if any
	# initiate a logger
	logger = system.util.getLogger( 'deleteOldFiles' )
	# get a dataset of all registered agents
	agentsDataset = shared.util.getAgentList()  # custom function returns a dataset of Agents
	# check to see if there are backup files on each Agent Gateway
	for row in range( agentsDataset.rowCount ):
		server = agentsDataset.getValueAt( row, 'Name' )
		serverFilePath = backupFilePath + server
		if system.file.fileExists( serverFilePath ):
			# get a list of all of the backup folders for the Agent
			backupFolders = glob.glob( serverFilePath + backupFileMask )
			# create a dataset with all of the backup folders
			dsHeader = ['backupPath']
			dsData = []
			for backupFolder in backupFolders:
				dsData.append( [backupFolder] )
			dsBackup = system.dataset.toDataSet( dsHeader, dsData )
			# determine how many backup files to delete
			backupsToDelete = max(dsBackup.rowCount - backupRetentionCount, 0)
			# sort the backup folders oldest to newest
			dsBackup = system.dataset.sort( dsBackup, 0, True )
			# delete files in backup folders then remove the backup folders
			for row in range( backupsToDelete ):
				# get a list of the files in the backup folder
				filesInBackupFolder = glob.glob( dsBackup.getValueAt( row, 0 ) + '\*' )
				for fileInBackupFolder in filesInBackupFolder:
					try:
						# delete the file
						os.remove( fileInBackupFolder )
						# log the delete
						logger.info( 'deleted file: %s' %fileInBackupFolder )
					except:
						# log a failure to delete the file
						logger.info( 'failed to delete file: %s' %fileInBackupFolder )
				# remove the backup folder
				try:
					os.rmdir( dsBackup.getValueAt( row, 0 ) )
					logger.info( 'removed backup folder: %s' %dsBackup.getValueAt( row, 0 ) )
				except:
					# log a failure to remove the backup folder
					logger.info( 'failed to remove backup folder: %s' %dsBackup.getValueAt( row, 0 ) )
@martinel3746 I was trying to get your script for removing backups working and see you have a custom function that returns the agents on a gateway. Would you mind sharing the code that you are using for this?
Thanks!
We register unlicensed agents in EAM even though the connections fail when they are not in trial mode.
The EAM controller gives us a good place to manage them – we have over 130 last time I counted.
Here’s my function for getting only the licensed agents from the EAM Controller:
#             Purpose:              To get a list of the licensed Agent Gateways connected to this Controller
#             Parameters:       None
#             Returns:               dataset of licensed agents
#             Change Management
#             Date               Who               What
#             03-Jul-2018         Lynn Martineau   Original Version
#             18-Aug-2021         Lynn Martineau   updated for Ignition 8.1
def getAgentList():
     agentList = []
     allAgents = system.tag.browseTags( '[System]Gateway/EAM/Agents' )
     for agent in allAgents:
           licensePath = '[System]%s/Independent/LicenseKey' %agent.path
           licenseKey = system.tag.readBlocking([licensePath])[0].value
           if licenseKey != None:
                agentList.append( [agent.path, agent.name] )
     agentDataset = system.dataset.toDataSet( ['Path','Name'], agentList )
     agentDataset = system.dataset.sort( agentDataset, 'Name' )
     return agentDataset
Just for kicks while I’m on topic, here’s a WebDev script that I use fairly regularly.
It gives me a quick list of servers without needing to visit the gateway:
	# Access this service via:
	# http://eamControllerName:8088/system/webdev/AgentManager/agents
	import system.dataset
	agentData = system.eam.queryAgentStatus()
	htmlData = system.dataset.dataSetToHTML( True, agentData, 'EAM Agents' )
	return {'html': htmlData}
@martinel3746 Thanks a million. Got this up and running this morning!
I like that script to return all agents from a web call. I was looking at building something similar with perspective.
I just updated the web client to add the agent’s IP address, an active link to the agent gateway, CPU Usage and Memory Usage.
	# http://yourServerName:8088/system/webdev/yourProjectName/yourWebDevScriptName
	# get the basic EAM agent data into a dataset
	tagPaths = []
	cpuPaths = []
	memPaths = []
	# populate lists of tags to collect data about the agents
	for row in range( agentData.rowCount ):
		tagPaths.append( '[System]Gateway/EAM/Agents/%s/Independent/BrowserURL' 				%agentData.getValueAt(row,'AgentName') )
		cpuPaths.append( '[System]Gateway/EAM/Agents/%s/Independent/Metrics/System/CPU Usage' 	%agentData.getValueAt(row,'AgentName') )
		memPaths.append( '[System]Gateway/EAM/Agents/%s/Independent/Metrics/System/Memory Usage'%agentData.getValueAt(row,'AgentName') )
	# read agent data tags
	tagValues = system.tag.readBlocking( tagPaths )
	cpuValues = system.tag.readBlocking( cpuPaths )
	memValues = system.tag.readBlocking( memPaths )
	# initialize lists for column inserts
	ipList = []
	linkList = []
	cpuList = []
	memList = []
	# populate lists of agent data
	for index in range( len(tagValues) ):
		linkList.append( tagValues[index].value )
		# parse to just the IP address - this is important for the text replacements to build the HTML link
		ipList.append( tagValues[index].value.replace('http://','').replace(':8088','') )
		cpuList.append( cpuValues[index].value )
		memList.append( memValues[index].value )
	agentData = system.dataset.addColumn( agentData, 1, ipList,		'IpAddress',str )
	agentData = system.dataset.addColumn( agentData, 2, linkList, 	'Link', 	str )
	agentData = system.dataset.addColumn( agentData, 3, cpuList, 	'CPU Usage',float )
	agentData = system.dataset.addColumn( agentData, 4, memList, 	'Mem Usage',float )
	# convert the dataset to HTML
	# add HTML construct for the links.
	# Note: if this is done prior to getting the htmlData, it all displays as text and will not function as a link
	htmlData = htmlData.replace( 'http://', '<a href="http://' )
	htmlData = htmlData.replace( '8088', '8088" target=_blank>Link</a>' )
@tbackus I was just working on the same thing and thought I’d share my solution for anybody else that may still be having this issue. We are using EAM to gather gateway backups from all of our edge gateways. In order to purge the old backups, I created a batch file on the EAM Controller PC (it is running Windows 10) and scheduled it to run daily. The contents of the batch file are displayed below. It will delete anything within the C:\Ignition Backups folder and subfolders that has been last modified more than 14 days ago. I know this solution lies outside of the realm of Ignition, but it is easy to incorporate and it works well.
forfiles /p "C:\Ignition Backups" /s /m *.* /d -14 -c "cmd /c del @PATH"
Please vote on EAM Purge Backups.
Managing the backup files created by EAM should be managed via EAM configuration.
