EAM - Send Tags to Servers Errors
I was trying to use the EAM Send Tags function but am getting a number of errors in some of the UDTs.
There's quite a few but one I've tracked down to a tag that was manually added to a UDT with a nested UDT. They then added a tag to a folder in that nested UDT.
UDT with no parent data type.
Has a nested UDT in it with a data type.
The nested UDT has a folder with one tag in it.
At some point in the base UDT, they added a tag inside that nested UDT folder. When I try to import through EAM or an import file, it complaints it can't add tags.
Point does not have item 'Missing Point' for overrides, and cannot accept children tags.
So in the UDT definition editor, I can add a tag to this nested UDT folder but I'll not be able to export it and import it?
Sounds like a bug. You should open a ticket.
Ticket opened. I'll try to remember to update this thread if we find anything.
I sent them logs and described everything but they just sent a message asking me to let them know if I figure out what the problem is. :slight_smile:
