We are working through a tag-naming and tag-folder-organizing problem. i think this is a common goal, but haven’t seen an easy way to do it.
Goal:
Have a tag tree that allows us to view machines in a number of different paths. Let’s say there are 50 tags related to one of our stamping presses … commonly known as StampingPress Baker10. It was made by ACME Corporation, Model DEF, and has SN 12345
- Location: the path to the tags would be State\City\Plant\Area\…\CommonName
- Coyote\PlantA\AreaB\SectionC\StampingPress\Baker10
- AssetTracking: the path to the tag would be based on function, manufacturer, model, serial number
- StampingPress\Acme\DEF\12345
- MaintenanceTeam: the path would be just a list of tags by CommonName
- Maintenance\Baker10
We are familiar with derived tags … but … was wondering if there’s a way to more easily create a folder of derived tags (i.e. select a folder … click on COPY … have an option for PASTE … PASTE AS DERIVED
Notes:
- We do understand that we could just create our own database of tag paths and then mix/match as needed. But we think (?) that there will be value in having these alternate views of the machine embedded in a tag tree instead of a database.
- We have a UDT that is supposed to be instantiated with each asset, that tracks Mfr, Model, SerialNumber, GlobalTrackingNumber, Category, CommonName … so we CAN devise a method of re-arranging the “view” based on the contents of that UDT.
What do folks do about this?
