Cant seem to bind tags to hidden/enabled in the tag pens dataset for the easy chart. Ive also tried adding the [~] infront of the tag values with no luck.
Cell Bindings don’t do indirect tags for you. The bindings for the ENABLED column need to point at boolean custom properties. Those boolean custom properties would have the indirect binding to the given tag paths.
