Hi All,
I want to Chart Value from a data base with Easy Chart. In my table the date has the format yyyy-mm-ddT hh:mm:ssZ as a VARCHAR.
In Easy Chart Customizer when I select the time Column i have this error: “The type of time column ‘date’ is not a date”.
This is normal because date is a VARCHAR
In Easy Chart, how or where can i convert this VARCHAR to a datetime?
Thank you for you help!
