I have problem with Easy Chart Customizer.
Since yesterday I am not able to edit SQL Tags Historian Pens and add new tag pens in Easy Chart.
I am still able to delete tag pens and and browse tag pens.
Same with Database Pens and Calculated Pens.
Here is quote from Java Console, what happens when I am pressing Edit Pen button:
[quote]Exception in thread “AWT-EventQueue-0” java.lang.NullPointerException
at com.inductiveautomation.factorypmi.designer.property.customizers.easychart.PenEditPanel.createTitledBorder(PenEditPanel.java:390)
at com.inductiveautomation.factorypmi.designer.property.customizers.easychart.PenEditPanel.initLayout(PenEditPanel.java:339)
at com.inductiveautomation.factorypmi.designer.property.customizers.easychart.PenEditPanel.(PenEditPanel.java:136)
at com.inductiveautomation.factorypmi.designer.property.customizers.EasyChartCustomizer$PenPanel$PenEditor.(EasyChartCustomizer.java:1150)
at com.inductiveautomation.factorypmi.designer.property.customizers.EasyChartCustomizer$PenPanel$PenEditor.editPen(EasyChartCustomizer.java:1134)
at com.inductiveautomation.factorypmi.designer.property.customizers.EasyChartCustomizer$PenPanel$EventHandler.actionPerformed(EasyChartCustomizer.java:886)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$000(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
at java.awt.WaitDispatchSupport$2.run(Unknown Source)
at java.awt.WaitDispatchSupport$4.run(Unknown Source)
at java.awt.WaitDispatchSupport.enter(Unknown Source)
at java.awt.Dialog.show(Unknown Source)
at java.awt.Component.show(Unknown Source)
at java.awt.Component.setVisible(Unknown Source)
at java.awt.Window.setVisible(Unknown Source)
at java.awt.Dialog.setVisible(Unknown Source)
at com.inductiveautomation.factorypmi.designer.property.CustomizerDialog.setVisible(CustomizerDialog.java:153)
at com.inductiveautomation.factorypmi.designer.property.propertytable.PropertyTablePanel.handleCustomizerAction(PropertyTablePanel.java:223)
at com.inductiveautomation.factorypmi.designer.model.CustomizerAction.actionPerformed(CustomizerAction.java:40)
at javax.swing.AbstractButton.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
[/quote]
