Easy Chart: Database pen
Hi everyone,
I am trying to use the database pen functionality in Easy chart. I'm getting the following error
"Error running query: SQLQuery(query=SELECT t_stamp, AT 107 FROM analyzer WHERE t_stamp >= ? AND t_stamp <= ? ORDER BY t_stamp, database=MySQL)@0ms On: Z4 TRENDS (1).Root Container.Easy Chart"
Did I miss something here:
Thanks in advance
Having a space in the column names is not considered good practice.
You didn't specify which db you're using, but try putting it in quotes, e.g. "AT 107"
Thank you @JordanCClark , I Just removed the spaces and it worked. :+1:
