Easy chart - Drag and drop tags from a Tag browse tree
Hello. I have a Tag browse tree and I can drag and drop tags to an Easy chart. But I want to show the full path of the tags as its Name in the Pen Control. And I want to add a new Axis for the new dropped tag.
Is there an easiest way to do it than overwrite the onTagsDropped event and add the tag in the script to the DataSet of Tag Pens, and add an Axis to de Dataset of Axis to assign it to the new tag? Then if a tag is removed from the Pen Control I should have to remove its Axis…
Thanks!
Hi, I have the same doubt, did you manage to solve this problem? Thanks
