I’d like to plot data from a SQL Server database table in an Easy Chart. I use a Database Pen for that.
The table is in a schema of its own named logs. The pen editor can see the table and the Run diagnostics validates my pen configuration correctly:
But as soon as the Easy Chart component gets running, I get the following error:
It seems that Ignition forgets that my table is not in the dbo default schema, hence the wrong query SELECT … FROM tbl_AuxHistory instead of FROM logs.tbl_AuxHistory .
Any suggestions, other then transfering the table in the default schema?
Thank you in advance,
regards
