I get the following error when trying to set an easy chart database pen to a bargraph. The error doesn’t go away when I press ok and usually results in me having to restart designer. I am running ignition 7.3.2
java.lang.ClassCastException: com.inductiveautomation.factorypmi.designer.property.customizers.easychart.PenStyleRenderer$SillyDataset cannot be cast to org.jfree.data.xy.IntervalXYDataset
at org.jfree.chart.renderer.xy.XYBarRenderer.drawItem(XYBarRenderer.java:745)
at org.jfree.chart.plot.XYPlot.render(XYPlot.java:3378)
at org.jfree.chart.plot.XYPlot.draw(XYPlot.java:2950)
at com.inductiveautomation.factorypmi.designer.property.customizers.easychart.PenStyleRenderer.paintComponent(PenStyleRenderer.java:95)
at javax.swing.JComponent.paint(Unknown Source)
at javax.swing.JComponent.paintChildren(Unknown Source)
at javax.swing.JLayeredPane.paint(Unknown Source)
at javax.swing.JComponent.paintToOffscreen(Unknown Source)
at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(Unknown Source)
at javax.swing.RepaintManager$PaintManager.paint(Unknown Source)
at javax.swing.RepaintManager.paint(Unknown Source)
at java.awt.GraphicsCallback$PaintCallback.run(Unknown Source)
at sun.awt.SunGraphicsCallback.runOneComponent(Unknown Source)
at sun.awt.SunGraphicsCallback.runComponents(Unknown Source)
at java.awt.Container.paint(Unknown Source)
at java.awt.Window.paint(Unknown Source)
at javax.swing.RepaintManager.paintDirtyRegions(Unknown Source)
at javax.swing.RepaintManager.seqPaintDirtyRegions(Unknown Source)
at javax.swing.SystemEventQueueUtilities$ComponentWorkRequest.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.Dialog$1.run(Unknown Source)
at java.awt.Dialog$3.run(Unknown Source)
at java.awt.Dialog.show(Unknown Source)
at java.awt.Component.show(Unknown Source)
at java.awt.Component.setVisible(Unknown Source)
at java.awt.Window.setVisible(Unknown Source)
at java.awt.Dialog.setVisible(Unknown Source)
at com.inductiveautomation.factorypmi.designer.property.customizers.EasyChartCustomizer$PenPanel$PenEditor.editPen(EasyChartCustomizer.java:1119)
at com.inductiveautomation.factorypmi.designer.property.customizers.EasyChartCustomizer$PenPanel$EventHandler.actionPerformed(EasyChartCustomizer.java:875)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at com.inductiveautomation.factorypmi.designer.property.CustomizerDialog.setVisible(CustomizerDialog.java:153)
at com.inductiveautomation.factorypmi.designer.property.propertytable.PropertyTablePanel.handleCustomizerAction(PropertyTablePanel.java:217)
at com.inductiveautomation.factorypmi.designer.model.CustomizerAction.actionPerformed(CustomizerAction.java:40)
at javax.swing.AbstractButton.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
Ignition v7.3.2 (b533)
Java: Sun Microsystems Inc. 1.6.0_18
