Easy Chart exportExcel rename headers?
button script:
easyChart = event.source.parent.getComponent('ChartContainer').getComponent('Easy Chart')
easyChart.exportExcel('myFileName.xls')
I want to change the header from 'Cut/jobpress' to 'jobpress'?
How to change?
Tip: Wiki - how to post code on this forum.
Rather than use exportExcel directly, you will need to use exportDatasets from Vision - Easy Chart Scripting Functions - Ignition User Manual 8.1 - Ignition Documentation.
Once you have your dataset(s) then using this example to update the column headers: Rename the column of a dataset - #2 by lrose
Then you can use system.dataset.exportExcel - Ignition User Manual 8.1 - Ignition Documentation to export the data to excel.
One approach that I've used for this involves getting the data from the chart indirectly, and then, changing the header names before using system.dataset.exportExcel/CSV to save the file. Here is an example that has been adapted for this use case:
# Get the easyChart component
# This function extracts the row data from the supplied dataset.
# ...Then, it creates a new dataset using the provided headers
def renameHeaders(dataset, headers):
	values = [[dataset.getValueAt(row,col) for col in range(dataset.columnCount)] for row in range(dataset.rowCount)]
	return system.dataset.toDataSet(headers,values)
# Get the tag paths column as a java list
tagPaths = list(easyChart.tagPens.getColumnAsList(easyChart.tagPens.getColumnIndex('TAG_PATH')))
# Create a list with the desired header names
headers = ['Time Stamp', 'jobpress']
# Get the displayed start date and end date from the chart
startTime = easyChart.zoomedStartDate
endTime = easyChart.zoomedEndDate
# Get the easy chart's dataset indirectly with a tag history query using the easy chart's parameters
tagHistory = system.tag.queryTagHistory(paths=tagPaths, startDate=startTime, endDate=endTime, returnSize=-1, aggregationMode="Maximum", returnFormat='Wide', noInterpolation=True)
# Use the renameHeaders function to replace the headers that were returned by the tag history query
dataset = renameHeaders(tagHistory, headers)
# Create an xls file using the modified dataset
system.dataset.exportExcel('myFileName.xls', True, dataset)
Result:
Edit:
@bschroeder posted his reply while I was putting mine together, so I didn't notice it. I tested the exportDatasets he listed and was pleased to see that it also returns only the displayed [zoomed] values. Here is the above example adapted to use that method:
# Use the renameHeaders function in conjunction with exportDatasets
# ...to produce a dataset with the desired header names
dataset = renameHeaders(easyChart.exportDatasets()[0], headers)
Thank you very much!
I used this example in exchange.
Ignition Exchange | Inductive Automation
So in fact, the headers is dynamic.
I don't konw how to get the dynamic headers in easy chart.
headers = ['Time Stamp', 'CUT/jobprss']    # I don't konw how to get the dynamic headers in easy chart
# 定义headers映射
headersMapping = {
    'CUT/jobprss': u'jobprss',
    'COOLER/UTLM16/V2': u'冷冻机组/M16冰水出水温度',
    'COOLER/UTLM16/V3': u'冷冻机组/M16冰水回水温度',
    'COOLER/UTLM17/V2': u'冷冻机组/M17冰水出水温度',
    'COOLER/UTLM17/V3': u'冷冻机组/M17冰水回水温度'
# 修改headers
newHeaders = [headersMapping.get(name, name) for name in headers]
It looks like you could get the headers you want dynamically by doing this:
# Get the pen names, some of which contain '/' this character
penNames = easyChart.tagPens.getColumnAsList(0)
# Set the first header to t_stamp
# ...and get anything after the last '/' character in each pen name
headers = ['t_stamp']
for name in penNames:
	headers.append(name.split('/')[-1])
Edit: Almost forgot that the column headers have to include the time stamp
Also, if you need to filter out disable pens, the code could be modified in this way:
for row, name in enumerate(penNames):
	# Filter out disabled pens
	if easyChart.tagPens.getValueAt(row, 'Enabled'):
Thank You very much!:hugs:
penNames = easyChart.tagPens.getColumnAsList(1)
print(penNames)
    headers.append(name.split(']')[-1].upper())
#print(headers)
# Define headers mapping as a list of tuples
headersMapping = [
    (u'CUT/PRESS', u'剪切机/压力'),
    (u'CUT/INTEMP', u'剪切机/进料温度'),
    (u'CUT/OUTEMP', u'剪切机/出料温度'),
    (u'CUT/JOBPRESS', u'剪切机/工作压力')
# Modify headers
newHeaders = [next((new_name for old_name, new_name in headersMapping if old_name == header), header) for header in headers]
print(newHeaders)
