Easy Chart - Fixed Y axis Range
Hi.. I am using easy chart component and have observed that when the pen value is not changing, the Y axis of the component auto ranges itself to fit the constant values. For example here the Y axis range is between -273.53 to -273.43
Is there any option to put a fix Y axis range for easy chart?
Yes, edit the Axes tab in the chart configuration, and turn off auto range.
