I started with the Easy Chart “click to graph” goodie but have made many changes to how the chart is loaded. I am not using the click to graph components. I have a screen with list boxes that select the pens to use.
I am in the process of removing code that is no longer needed.
Since I am creating the pen query myself do I need the ctg_active_client table?
What was this originally for?
If I understand it correctly the ctg_active_client table is used to keep track of ‘click_to_graph’ items that are selected at runtime. If this is the case can I safely remove references to this?
