I’m looking to remove the minus numbers from the y-axes on the graph. The flow is reading 0.4 which in turn is showing an upper bound of 0.6 and a lower bound of -0.3. I have tried turning off the auto range but because other flows on the project are a lot higher it sets the upper bound to 100 which in turn makes the 0.4 flow barely visible.
Is there a way of removing the minus numbers without turning off the auto range?
Please see attached for example
Many thanks
