Easy Chart Indirect Binding -Vision
Currently I am working on easy chart in vision in which I am passing the tagpaths indirectly.
Pictures for ref,
Whenever i navigate to this screen, I got the below error message in the gateway but the screen is working properly.
How to overcome this error?
Is there any way to pass the tagpaths via scripts for easychart?
Thanks in advance.
Hi Dharani,
First, I'd double check that tag history is enabled for the given tags.
Second, I'd check that the tag paths shown in the logs are legitimate (ie, do they exist?).
Beyond that, I'd make sure to try using fully qualified paths.
Please see the following section on Path Components here:
https://docs.inductiveautomation.com/display/DOC81/DB+Table+Historian+Provider#DBTableHistorianProvider-PathComponents
