Running 7.7.0 (b2014071516)
Easy charts appear mostly upgraded ok but I have a couple that misbehave since the upgrade
- Only shows data post upgrade, although previous historical data is present.
Chart1.png shows the chart as depicted post upgrade
Exporting CSV through API for this chart data yields “filter.csv” data. I’ve also included the chart.xls dump from the chart itself and it also shows the data being present - so it looks like it is not being rendered. (We cannot use the XLS dump as we use openoffice and it fails to import the times so we use a template that uses the tag pen data to export csv)
As you can see data exists for the whole data range.
- I have a chart with lots of tags and subplots that shows no data until I remove a single tag and replace it.
In the tag pen dataset it then shows an appended relative path tag [~] for the replaced tag. Chart then automagically works again for all tags.
[I also note it defaults to user removable with no GUI option to change in the editor (I would assume that defaulting to not user removable would be expected behaviour)]
Below is the tag pen dataset showing the weird behaviour. Without the [~] on a tag it does not work for any tags. Put one [~] and it all works.
Regards
Tarek
chart.csv (3.07 KB)
filter.csv (16.2 KB)
Chart.xls (108 KB)
