Easy Chart no Taking Changes
Have an Easy Chart that has been working for a couple years.
Ignition Platform 8.1
The Chart has 9 Subplots each with their own pen. This is not a template. When i try to edit a subplot for the Upper Range, it takes just fine in Designer. But after i finish and save and commit changes, i most of the time reverts back to what i started with. Occasionally, it will take the changes, but i cannot find what is the "magic" sequence. I have edited the ranges in the Easy Chart Customizer. Also edited in the Chart Configuration "Axes" Dataset. All will look great and appear to save correctly but when i close and re-open the chart, it may, or more likely not have those changes. Any suggestions or ideas?
Look for bindings or scripts that are overwriting your changes.
Thanks Phil. I found that if i go through every setting Chart Configuration, and the customizer then to the properties and make the changes to all these before saving, its working MOST of the time.
