I looked around and couldn’t find any topics in regards to this issue. If I missed something, feel free to point me in the right direction.
I have any easy chart in my project that is pulling tag history from a MySQL database. On this chart I have 30-40 pens all set to “Line” style. Most of the pens plot fine. However, I have a few pens that will not plot a continuous line and instead have many gaps. It makes the graph pretty much unreadable for those pens. Image below of one of the pens having issues.
It appears to be related to a data density issue. Currently the tags are set to record based solely on deadband and can have unlimited time between points. If I set the tag to record and limit the time between points to a few minutes, the plot line will look much better. Is there a way to fix the plotting issue without increasing the data density?
Thanks in advance,
-Will
Pen With Gaps:
[attachment=0]Screen Shot 2016-06-01 at 11.30.32 AM.png[/attachment]
Specs:
Ignition 7.8.2 (b2016030813)
Reporting Module 3.8.2 (b2016030813)
Server Java v8 u65
Server is Windows 7, 32 GB RAM, 8 Core ?Hz
Designer Running on Mac OSX 10.11.4
Designer Java v8 u66
