Easy Chart Pen Edits
Hello,
Ignition 8.1.26
Vision 11.1.26
We have many different lines that are "the same as but different" and not to get into the discussion of templates or rework or such, we've found it easier to copy and paste and handle some details on an individual basis. That said, we do use Custom Properties and Cell Update Bindings for a bulk of the work.
Regarding the single Easy Chart on the window, I'm attempting to remove some tags. When I remove the Pen from the Easy Chart Customizer and then from the Cell Update Dataset, the Tag Names seem to update, though the Tag Paths remain. So let's say I remove Pen 2, I'm left with:
Tag Name 1 -- Tag Path 1
Tag Name 3 -- Tag Path 2
Tag Name 4 -- Tag Path 3
and so on...
For what it's worth, the Cell Bindings update, so I no longer see Row 2, but in both the Chart Customizer and Dataset, I have the same results.
I've seen tag issues before (v 7.9 - I'm new to v 8) that the only workaround is to just delete the tag and start again (no amount of reconfiguration helps), but I'd like to not have to reconfigure dozens of pens, groups, and other trend properties. I've closed windows without saving and started over, copied or duplicated windows, and even restarted the designer.
Has anyone run into this? Am I missing something?
Cell update bindings generally cannot handle variable numbers of rows. Script your pen configuration updates instead.
