Easy Chart Plot Background Binding Preventing Window From Opening In Designer
I have bound a plot background on an easy chart to a color client tag and now when I try to open the window in the designer I get the following error and the window refuses to open:
The window DOES open in the client successfully but now I am unable to open the window in the designer to modify anything. This is on Ignition version 8.0.8.
java.lang.Exception: Error setting property to 'java.awt.Color[r=249,g=247,b=231]' for binding on
Injection Percent Scale 1.Root Container.Easy Chart.plotBackground
	at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.updateTarget(AbstractPropertyAdapter.java:335)
	at com.inductiveautomation.factorypmi.application.binding.SimpleBoundTagAdapter.updateTarget(SimpleBoundTagAdapter.java:538)
	at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.updateValue(AbstractPropertyAdapter.java:266)
	at com.inductiveautomation.factorypmi.application.binding.SimpleBoundTagAdapter.notifyTagChanged(SimpleBoundTagAdapter.java:503)
	at com.inductiveautomation.factorypmi.application.binding.SimpleBoundTagAdapter.tagChanged(SimpleBoundTagAdapter.java:491)
	at com.inductiveautomation.factorypmi.application.sqltags.ProjectTagSubscriptionManager.subscribe(ProjectTagSubscriptionManager.java:109)
	at com.inductiveautomation.factorypmi.application.sqltags.project.ProjectTagManager.subscribe(ProjectTagManager.java:423)
	at com.inductiveautomation.factorypmi.application.sqltags.project.ProjectTagManager.subscribe(ProjectTagManager.java:407)
	at com.inductiveautomation.ignition.client.sqltags.impl.SubManagerAdapter.subscribeAsync(SubManagerAdapter.java:115)
	at com.inductiveautomation.ignition.client.tags.impl.ClientTagManagerImpl.lambda$subscribeAsync$8(ClientTagManagerImpl.java:246)
	at com.inductiveautomation.ignition.gateway.util.GroupMapCollate.lambda$groupMapIndexed$10(GroupMapCollate.java:89)
	at java.base/java.util.stream.ReferencePipeline$3$1.accept(Unknown Source)
	at java.base/java.util.HashMap$EntrySpliterator.forEachRemaining(Unknown Source)
	at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
	at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
	at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
	at java.base/java.util.stream.AbstractPipeline.evaluateToArrayNode(Unknown Source)
	at java.base/java.util.stream.ReferencePipeline.toArray(Unknown Source)
	at com.inductiveautomation.ignition.gateway.util.GroupMapCollate.groupMapIndexed(GroupMapCollate.java:98)
	at com.inductiveautomation.ignition.client.tags.impl.ClientTagManagerImpl.subscribeAsync(ClientTagManagerImpl.java:234)
	at com.inductiveautomation.ignition.common.tags.model.TagManager.subscribeAsync(TagManager.java:73)
	at com.inductiveautomation.factorypmi.application.binding.SimpleBoundTagAdapter.startup(SimpleBoundTagAdapter.java:145)
	at com.inductiveautomation.factorypmi.application.binding.DefaultInteractionController.startupBindings(DefaultInteractionController.java:355)
	at com.inductiveautomation.factorypmi.application.binding.DefaultInteractionController.startupAdapters(DefaultInteractionController.java:360)
	at com.inductiveautomation.factorypmi.application.FPMIWindow.startup(FPMIWindow.java:344)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace$DesigntimeWindowOpener.openWindow(WindowWorkspace.java:3513)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.openWindow(WindowWorkspace.java:1294)
	at com.inductiveautomation.factorypmi.designer.model.navtree.WindowNode.open(WindowNode.java:270)
	at com.inductiveautomation.ignition.designer.navtree.model.AbstractResourceNavTreeNode.onDoubleClick(AbstractResourceNavTreeNode.java:266)
	at com.inductiveautomation.ignition.designer.navtree.NavTreePanel$MouseListener.lambda$mousePressed$0(NavTreePanel.java:656)
Caused by: java.lang.ArithmeticException: / by zero
	at com.inductiveautomation.factorypmi.application.components.chart.easychart.ConstantPenDatasource.createTimeColumn(ConstantPenDatasource.java:124)
	at com.inductiveautomation.factorypmi.application.components.chart.easychart.ConstantPenDatasource.updateData(ConstantPenDatasource.java:108)
	at com.inductiveautomation.factorypmi.application.components.chart.easychart.ConstantPenDatasource.startup(ConstantPenDatasource.java:80)
	at com.inductiveautomation.factorypmi.application.components.PMIEasyChart$EasyChart.startup(PMIEasyChart.java:2230)
	at com.inductiveautomation.factorypmi.application.components.PMIEasyChart$EasyChart.createChartImpl(PMIEasyChart.java:2772)
	at com.inductiveautomation.factorypmi.application.components.chart.PMILineChartPanel.createChart(PMILineChartPanel.java:135)
	at com.inductiveautomation.factorypmi.application.components.chart.PMILineChartPanel.setPlotBackground(PMILineChartPanel.java:341)
	at com.inductiveautomation.factorypmi.application.components.PMIEasyChart.setPlotBackground(PMIEasyChart.java:1188)
	at jdk.internal.reflect.GeneratedMethodAccessor1164.invoke(Unknown Source)
	at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.updateTarget(AbstractPropertyAdapter.java:328)
	... 42 more
Ignition v8.0.8 (b2020021111)
Java: Azul Systems, Inc. 11.0.5
In the designer before opening the window, can you try Shift Right click > copy XML to clipboard? Paste it into notepad, modify or remove the binding. Then Shift Right Click and Set XML from clipboard.
Is this the binding in XML?
That’s the only thing that I see when I search for plotBackground. If I delete that section and then copy everything and Set XML from clipboard it doesn’t do anything… I saved the project and then recopied the XML and this still is in there.
