Easy chart question
Hello
I am trying to chart a db entry with easy chart. The table I want to chart has two columns, date and date.
date is type date with getdate() default value. Data is type float.
(I am using sql server)
When I goto pen database select the proper things, when I run Diagnostics it says ‘The type of time column ‘date’ is not a date.’
If I goto chart the error I get is
"IllegalArgumentException: Illegal type for x value: class java.lang.String (column ‘date’)
using the query select data, date from tablename
sample data from dataset viewer
date | data
yyyy-mm-dd | 1
yyyy-mm-dd | 2
Try:
SELECT CONVERT(DATETIME, date) as date, data from tablename
It could be that your date column is not being correctly interpreted as a date value.
that was it. Thank you!!!
