I did search the forum, but am still stumped. How do I remove the ability for a user to remove a pen from a easychart? I need to deselect user_removable, but where is that option?
Hi andy?
Welcome
I’m not sure how you are populating the chart but you could try the following:
Select the easy chart and then find “Chart Configuration” as a group heading in the “Property Editor” (usually the panel on the bottom left of your screen), click the Dataset Viewer button (it looks like a table with a magnifying-glass) for the pens dataset you use. The very last column is the “user_removable” setting, un-tick or tick as required.
If the Dataset has a binding then you will have to look to the binding source and make changes there.
Much thanks! I see it now.
